- Joined
- 5 Sep 2015
- Messages
- 10
- Reaction score
- 0
- Country
Victorian semi with a basement, which has a sump in a corner near the external wall. I bought the place with a sump pump installed and that's fine but the drainage arrangements are horrible. The outflow from the pump goes into a length of corrugated plastic drainage hose which heads up the basement wall, out of a very small height ground-level window opening (no window but a rusty grille and the hose goes through a hole in it), along the side passage of the house and into a drain opening. There must be a better and more normal approach. I know that the drain passes under the side passage i.e. close to the sump location so there must be an option to get this thing draining into it without all the crazy hose. Should I speak to some kind of drainage contractor?
