corsa smashed steering
16 Apr 2006
Newcastle upon Tyne
help
some toe rag broke into my corsa and smashed the steering lock and tried to start it with a screw driver but the key code stopped them.
i remove the damage steering lock and put everything back together and the motor starts and cuts out after 10 to 20 seconds.
the keys ok the transponder seems to be intact and untouched but when i checked the desil filter thier wasot desil being pumped into it.
any ideas what is stopping the moror from running
thanks peter :(
Whenyou remove the lock make sure the ring that was fitted to the lock is left connected. that is the receiver for the key transponder. When my corsa was done the same way I removed the broken lock, taped the key to that ring and then started the car with a hidden switch that I fitted
