Hello I'm a first time buyer who just had an electrical report carried out on a property I'm looking at buying. It is a 1950s purpose built flat. The report has come back with some issues which the electrician has said need doing as they are quite serious.
For various reasons, we're having problems with our vendor reducing the cost of the property to accomodate for the cost of the work, so I have been advised by someone on another forum to get a 2nd opinion on how serious the problems are.
The work that the electrician has said needs doing immediately is:
- Mains electrics on ground floor worn, undersized, original braided construction.
- Mains earthing conductor undersized, adapted from original conduit construction. Boxed in, no access.
- Main lighting circuit does not have earth conductor with metallic light fittings installed in living room & bedrooms.
- Immersion heater does not have built-in cut out that will opperate if stored water temp. reaches 98oc if thermostat fails. Storage tank is plastic.
- Socket circuit 5 feeding sockets to hall, lounge, kitchen is 2.5mm radial fused at 30A (Overcurrent protective device too high to protect installed cables)
- Main socket circuit 4 does not have a dedicated CPC earth.
- Cooker cable runs through wall to isolator.
- No 30mA protection to socket circuits
- No 30mA RCD protection for cables burried in plaster at depth of 50mm or less - all circuits.
- No 30mA RCD protection to lighting circuit and heater in bathroom. Local supplimentary earth not present.
I don't suppose anyone could let me know if they are serious issues or not..? For what it's worth, our electrician was very good. It's just that I don't know anything about electrics and a 2nd opinion would be much appreciated!
