firstly no ive not been up all ight doing this before you ask. My youngest is up at 5.45.
Ok last night i took th front off the boiler and tried the pump at different speeds .
num3 the fastest wouldnt get all the rads hot. Number 2 made an improvement and after some time it slowly started to filter the heat around but it mad a fluctuating noise and the pressure needle on the gauge was jumping.
num 1 speed it nice and warm AHHH
so im assuming that on number 3 something is not catching the impellor so in turn not moving it and the heat is getting round by convection only?
number 2 speed is catching the impellor but not connecting fully causing it to slip which i think could be causing the noise and the needle movement
and number 1 speed is catching the impellor but just pushing the water round slowly.
would i be right in my diagnosis?
thanks for all you help on this one.
Regards Alan
1. Ignore all the nonsense about TRVs.
2. Buy a new pump.
3. Drain down.
4. Remove old pump.
5. Fit new pump.
6. Refill with Fernox (or equivalent).
7. Throw away old pump.
Your analysis has been streets ahead of anyone else posting on this topic - in the future you should trust your own judgment and go for it.
cheers for all the advice I have to admit ive actualy enjoyed working on the boiler (strange but true) so i may even look into a course just to see if i still enjoy it.?
anyone got any recomendations
