D
daniely87
hey, a couple of questions regarding electricity supply
1. if the mains board is 3 phase and has 3x100Amp fuses, can you put a 100A MCB on each of the phases? currently we have 63A MCB's, occasionally they may trip, so we will put them up to 80A MCB's, but i was wondering how over/underrated the 100A fuses the electricity board put in are? could i get away with a 100A MCB or is it too likely to blow the main fuses?
2. If i have a thick 3 core cable..i can run 3 phases down it?, i have a 3 phase supply entering my field to a box, where it branches off to other parts of the field.....i have run the new cable to the building we are in the middle of constructing..., someone today suggested a 3 phase heat pump...no one else has......is it possible to run 3 phase supply down the 3 core cable (very thick) AND use the remaining electric from the 3 phases / convert back to single phase? (if that makes any sense)
don't worry i am not going to attempt any of this myself! just electrician isn't back for a few days and i need to let the heat pump man know ASAP if 3 phase is available
thanks in advance!!
thanks in advance!!
