Currently contemplating bathroom refurbishment and have taken a look under the bath. There has been a fair bit of water leaking round the perimeter due to poor sealing, probably for some time, as you can see below!
Top bit of the joists looks a bit rotten, though the bulk of it still seems solid. What repair would you suggest? I'd be happy to sister a new joist, but one problem is that to the left in the picture is an airing cupboard then the hallway where there is a ground floor wall supporting the existing joists. I can't see that I can slide a full length joist underneath - would it be sufficient to have the sister just supported at one end, or would a shorter length spanning either side of the damage be enough?
Second - I have a paramount partition wall that will be studded out and re-boarded. Currently it's sitting on top of a joist. My understanding is stud walls should usually sit on doubled-up joists? Again I'd have trouble getting a full length joist in...
Spans are about 3m in both cases, 47x195 joists at 400mm centers.
