- Joined
- 6 Jul 2004
- Messages
- 37
- Reaction score
- 0
- Country
I bought my PC about a year ago . It contains an AMD Athlon 64 3200+,bus 2200Mhz, 1024kb ram, 204Gb Maxtor HD and NEC RW ND3540A DVD.
I loaded Itunes just after I bought it and over a period, loaded CDs on to it usually 6 or 8 one after the other without a problem. A few weeks ago, after loading about 3 Cds in succession the PC shut down. After leaving it for half an hour I could continue.This condition continued for a while but now I cannot load one CD without it shutting down. In normal use (surfing etc) it is fine.
I loaded PC Wizard and checked the CPU temperature. Under normal use it reports a CPU temperature of about 45C but when I start to load a CD it immediately rises at the rate of about 3 to 4 degrees C per minute so in a few minutes it hits about 80C at which point it shuts down.
I opened it up and found that the two case fans were both pushing air in so I reversed the rear one so it sucked air out but it has made little difference. The CPU fan is reported by PC wizard to be running at 3013rpm and when I feel the heat sink it only feels warm not hot. I suspected it was not making good contact to the CPU so I removed it but I can't see anything wrong. It has a thin film of heatsink compound and the clip is holding it very tightly to the CPU. The inside is all very clean . There is no dirt or debris on the heatsink fins.
I would appreciate any suggestions.
