Hi all,
I have a utility room, off my kitchen, which is basically the rear portion of my garage. The outer most wall, which seems to be just single brick construction, has a crack in it. I should say that it is a painted brick finish in the room, no plaster or other covering on brick. When I say single brick, I mean it doesnt seem to have cavity in it, but it seems to be quite thick, about 6-7 inches.
This crack runs from the floor to about 3/4 the way up the wall. On the inside, I have removed the paint surrounding the crack, the crack doesn't appear to be too wide, 1mm or less in places. The crack is also seen from the outside of the wall, where the exisiting roughcast finish is also cracked in the same place, to the same height. Something I noticed, but dont know if it's terribly relevant, is that it isn't the mortar that is cracked, but the brick itself.
My question is, and I appreciate that you can't give a definite answer unless you were to see it, but is this usually a sign of a major problem, or is it fairly common to expect some form of settlement, or slight movement of garage/utility structure room, that would account for this, given its single brick construction. (House is approximately 30 yrs old).
Obviously, its not at the extent that I'm prepared to tear the whole wall down and rebuild etc, but I would like your thoughts on whether generally, it's acceptable to 'patch up' the crack?
If so, could anyone give me some idea on how to do this? I have looked at some polycell products which would seem to provide a solution for the interior wall. But the exterior wall, with the crack in the roughcast seems a bit more difficult. Would I be ok to fill this crack with exterior silicon or something, to prevent moisture getting in?
I may be worrying about nothing here, I guess a lot of houses have cracks in roughcast and in interior, but hidden behind paper etc, but just looking for some advice.
Any ideas/thoughts gratefully appreciated.
Just to refine my original post to this...
Is it acceptable to apply silicon into the crack on the exterior roughcast?
