That's the only way I've ever seen it done.
Where? Photos? The only way.
I guess you ain't seen much done then.
I can push a screw driver into hemlites. (cinder block, ash block)
Try and push a piece of 2" timber into a block and see how far you get.
All 3.5n blocks will crack if you kick them.
Joe, the one thing you are forgetting is that most internal load bearing structures are built from blocks that are full of air and are 'soft' by comparison. These are preferred and recommended by all architects, all designers and all at b.c.
Where you get the idea that the internal walls of buildings are built form dense 7n type concrete block is total and utter horlics.
Some point load locations are either borne by padstones or dense blocks or bricks.
