Hi guys,
I realise this may be a pointless exercise and if convinced will drop the idea all together. I've stripped back a room and had it re rendered and skimmed. Also took out the chimney breast in order to make that wall more usable. The plan is to replicate built in wardrobes, but using three, 1m frames will sliding doors attached and I will then box these in with lighting etc.
As I have 3 frames, which will need to be perfectly joined and flush with each other I want to be able to have them on a very level base. The floor boards are not bad, but it's not perfectly level. I have 2 options I guess:
1. cut out the floor boards the depth of the wardrobes and place an 18 or 22mm sheet of ply down.
2. place a very thin ply sheet on top of the floor boards, but use some sort of liquid cement between the floor boards and ply that will allow me to set the ply level
I'd like to think 2 would be easier, but while typing this I'm beginning to think 1 would be (albeit I'd need to support the board at the cut as they would be between joist spans. Not sure it's really worth it, but I would feel better if I knew it was all level before starting.
