If you glue then screw the top sheet down it would help, I would have thought 18mm ply would have been fine for a floor as long as you noggin each joint...
Thank you tomfe. I can spend the holidays without worrying. You have just bough a sigh of relief for me.
My room is only 2.6m wide so a single 2.4m sheet covers most of the width. I have no joints in between joists. Only one joint per sheet on the last joist. Sheets are fitted in staggered pattern. Where exactly should i add noggins?
Forgot to add, space between joists is approx 32cm.
