- Joined
- 21 Dec 2009
- Messages
- 22
- Reaction score
- 0
- Country
I have a creda t622cw dryer, were the start button does not hold it's position, hence it cannot be turned on.
My plan was to swap the connectors between the on/off switch and the low/high heat button (as this is working) to test whether the it is just a case of replacing the switch.
The problem is access to the switches. I have removed the top, via 2 screws on the back. I then removed, what I thought was, the 4 screws (one in each corner) holding the control front panel. However there appears to be something , near the timer dial, which is holding the panel in place. It does not appear to be the timer dial itself.
Could someone please advise on the best way to access these switches, and whether my swapping of the connectors would cause a problem. As I have said above, I only intend on swapping the connection to the switches in order to see if that is the fault.
Any info will be appreciated.
