I have tried it at the sensor setting loaded with cloths taken out of washing machine. It ran about 55 mins. At the end cloths were nearly dry but cold the heater did not turn on throughout the cycle. I have checked the water tank overflow sensor. The machine halted when its overflow sensor was lifted up manually. I will check the exhaust thermostat later on.
The machine ran without any problem until last October-November when I replaced the thermostats. In December the drum was sticking and was producing unusual noises which was cured a bit by replacing the rear drum bearing because the actual root of the problem is rectified a few days ago with your fantastic advising help.
