I have read other posts on here where people have found crumbling bricks in the gable end/party wall in the loft.
I have that too.
I have repointed the lower bricks as the mortar was rotted but bricks fine.
Above, a few bricks are in a bad way and will be replaced.
However, on the chimney breast I have a bigger problem. The top (bit nearest the roof) is solid brick and mortar. The bit at the bottom (near the loft rafters) is solid as is the mortar.
However, in between, the bricks are in a bad way. Two are missing (hole into chimney breast). I planned to remove the bad bricks one by one and replace. However, I am worried that by taking out any more bricks, the whole lot might collapse.
Through the hole, I can see that there is a similar hole on the oposite side on my next door neighbours side.
As the chimney is on my property, how does his hole affect things?
I think this is beyond my skills.
1. Will a builder be likely to be able to repair the breast? My fear is that the whole thing will need to be taken down at great cost.
2. Any ideas of the sort of costs? I know you cant see the exact thing, but am I talking 1 grand or 10?
3. Is this urgent to fix?
I have that too.
