Needs a air vent in there. Now the floor covering is up it will breathe again.
You could do with a floor that will breath like carpet or ceramics but the best way is to clean it all up then put ardex DPM1c down
Do you know where's best/cheapest place to get a tub of ardex DPM1c? I don't need much.
And then once it's down and set, can I just put the next part of flooring down on top, such as the ceramic tiles or whatever I choose?
Any technique tips for applying it?
You can buy a 3kg of it. Look for a local flooring shop that sells Karndean or Amtico and they should be able to order you one. You will need 2 units ardex NA screed as well
