I picked up on a post from last year which indicates that:
"2.5 T+CPC cable can carry about 24 amps. In a ring, that effectively doubles it to 48 amps - it is protected by a 30Amp fuse/MCB, therefore safe"
but I can't find anything confirming this on the TLC site, so...
1. is this correct?
2. does this means the cable (not its protective MCB) could cope with an 11kW load ((48*240)(grouping / temp factors not yet included)
3. Assuming the above to be true, coud I safely use a 40A MCB?
All of the above is for planning purposes only, as I have a professional electrician lined up to do the work, but need to avoid going through the unit next door if at all possible
1. is this correct?
