Ye cannae change the laws of physics - if you want a hob that generates enough heat to be of any use then an electric one will use way too much power to be run off a 2.5mm² cable.dont all new cookers run on alot less power? I was told that all new stuff only needs 2.5mm as low power, not like the old stuff needing 6mm+ cable size.
Is this correct or have i been informed wrong?
You may have been confused by the careless use of the word "cooker" to mean "oven".
