You need a diamond drill, a bit like a small core drill. And they whould be run with a good water cooling system to minimise heat build-up (and the possibility of cracking) - at least that's how I've seen them done in my granite supplier's shop. It might be easier to go for the more traditional taps which attach to the wall above the worktop and have the pipework hidden in the wall behindAgile said:How do you cut a sink hole in the proper 30 mm stuff?
Scrit
