Hi, Want to put an oak mantle above my fireplace, it was goin to sit in the wall but basically the fireplace is too small so it is going to have to be attached to the front. I have two questions;
Firstly if i buy a piece H7" x D9" x W65" can I then cut out a section so it slides around the fireplace? I want about D6" as a mantle and the overhang is about 3" on each side, slightly concerned about how I can remove the excess wood without causing cracks to these smaller outer parts .
Secondly I wonder how to then fix it, my plaster has suggested using wall plate type fixing first affixing them to the mantle and then fixing those to the walls and plastering over. Or using large screws which would be fitted into the wall and then essentially creating the same size holes in the back of the wood before sliding them on and ficing them using some sort of no nails type solution?
Advice appreciated.
Advice appreciated.
