D
Deleted member 174758
And still needs to be recessed into the back of the mantel. Are you aware that the OP possibly doesn't possess an router? Also, if the split battens are in timber you still need to get the two pieces on the wall straight to each other AND there is a limit to how short you can make them if you use the most obvious material (softwood). I also notice you haven't detailed how you'd achieve this other than repeating "French cleats" mantra. Details of how to do this are required, methinksThis cleat principle is the best option.
A small cleat can be made to self level and align.
