Hi, I'm new here...first post!
We are currently considering converting a bathroom to a bedroom (mid terraced property) and downsizing the bathroom. All done to meet BC regs etc..
We have a typical vented indirect system with gas boiler with a cylinder in the bathroom at present. Both expansion/header tanks are directly above the cylinder approx 0.5m high. Main cold water tank is above them in a very small attic space. No issues with the system at all..works fine at the moment.
Because of the room required we want to relocate the cylinder downstairs in a cupboard close to the boiler. This will also have to include the expansion/header tanks in a similiar configuration.
We will only need a single hot tap to a sink upstairs as we will not have a bath or shower feeding off the hot water (electric shower).
Before we make bolder moves and start getting qoutes etc... Would there be a problem moving the cylinder downstairs (room directly below where it is now)? Also, I presume we would need an inline pump to serve the hot sink tap upstairs as this will be above the header tank...would there be an issue with this?
We do not wish to move to a combi boiler (cost!) and are working to a very tight budget. Any advice would be brilliant!
