And if you really can't make them join up elegantly, put a stop-end on each. A half-round end might look good, if you do a square one, chamfer off the edges.
If the dado rail is to go up a stairway, measure the required height for the rail at the points (top and bottom of the stairs) where the skirting board changes direction for the stairway, and use a chalked line between these marks to set the line for the rail.
That will not work and is not a very accurate way of marking out a stairway .the measurement on the stairs should be 90degrees of the angle of the staicase .Simple as that
90 degrees of the angle will give a vertical line.
A measurement at 90 degrees of the staircase will give a paraell line (which is right) not a veritical line, no where in your post does it mention a measurement taken at 90 degrees of the staircase
Splinter..Dont shot the messenger, I sent an extract & link from a web page. As reading the post the poster seemed confused.
Both ways will work.
When I did mine, I measured at 90 to the stairs & where it bisected the dado that was the change in direction.
I am not a pro, just a meticulous DIYer (well was this house finished now)
