- Joined
- 4 Aug 2019
- Messages
- 5
- Reaction score
- 0
- Country
I live in a 1930’s detached house with a 2ft crawl space under timber joists, but the crawl space floor is mainly clay and is quite wet/damp. There are a couple of air bricks around the sides of the house, but I am going to install some more to increase air flow.
The previous owners have had a sump pump installed with drainage paths dug into the clay that drains into the rainwater system and works quite well, there’s some standing water where the ground/clay is uneven where people have knelt down etc. but it’s only a couple of cm.
When it rains, water is seeping in through the brick work at the wall/floor joints and then the pump drains it away.
My issue is the clay is always damp even after periods of dry weather and it can take a long time for any standing water to eventually soak/evaporate away. Is this a problem that could cause moisture to get onto the timbers?
At present none of the joists have any damp/rot issues and all look ok
I was thinking of adding a couple of inches of shingle/crushed rock on top of the clay then a damp proof membrane and then another inch of gravel to help the water soak away and hopefully stop any moisture spreading to the joists.
Or would this cause more problems?
