What height did the cavity rubble reach?
Did you get water on the paving pooling against the wall? Any drains or downpipes nearby?
As i suggested before "just a scrape and paint" wont do - you will have to hack off etc.
Whichever way your joists run they will have been seated in a damp wall, & in all probability have fungal damage.
Go under the floor if its possible, and examine the conditions down there.
Your skirting is modern which suggests previous Remedial work has taken place.
Some timber suspended floors have a DPC beneath the floor joists and again at FFL.I dont understand: "DPC's at differing levels"? Do you mean all suspended floors or just this particular property?
And that's what is bridging the cold and the damp. No easy fix unfortunately. We actually replaced all the bricks at DPC level on a house by doing it in stages, rolling out the DPC as we went. Horrid job.From the top of the plinth externally I’m raking out 2 ft worth of crap
Damp doesn't always travel from below.Given that mechanical DPC's are the benchmarks for extensions etc - why would BCO allow variety in installations?
I still dont understand - why the extra time and expense of two DPC's? In what kind of wall?
Are you calling capped joist tails in brick pockets, or joist tails sitting on a bit of slate, DPC's?
Pre-1914 builds sometimes had weird DPC arrangements but they are exceptions. And i'm assuming that we are not talking exceptions?
Stepped DPC's are common enough when coping with changing ground levels, and only require the DPC to be stepped up - but there's still only a single stepped DPC.
