I have a 4" pipe coming into the extension, the top of which that comes in ~6" below the surface, then runs down the length of the extension and out the back.
the extension was built over an old garage, and the pipe runs along a concrete slab that I can only assume was the original foundations of the garage that the extension replaced.
Where the pipe comes in, since it is below the surface outside, there is damp coming in, and this then ends up sitting on the contrate slab - making the whole area under the floor very damp. (literally glistening on the surface of the concrete slab)
I've checked the pipe, and I'm 99% sure that its not leaking, so I guess the damp is coming in vis the large gap around the pipe (when you look down the length, the pipe goes under a small lintel, has a gap of about 2" on either side, and then after the outside wall goes directly into soil outside)
Is there anyway I can seal round the pipe?
Should I drill lots of holes in the concrete slab to allow water to soak away?
sorry for long question!
Thanks, Jon
Thanks, Jon
