I took an interest in damp problem 11 years ago when my sister has damp problem, the Damp company came round and took 1 metre plaster off the wall along the whole length of the wall. To cut a long story short, the company went bankrupt so the job didn't get completed. I was too busy at the time to re-plaster the wall, 7 months later it's still not done ! I've then replastered the wall and she not has any damp problem since. The only difference we've done was as her house back onto the alley way was to removed all the wild overgrown flowerbed and kept it down since then, the television used to sit on a low brick wall section next to the fireplace on both side which was removed by the damp company and the television now on a TV stand. Why the problem stopped I don't know, is it because the warm television now got a air-flow and no condensation trap by airlock pocket ? Now here me thinking if the the chemical treatment went ahead, physiological thinking no more damp because of the chemical treatment. As Thermo & masterbuilder said "it very difficult to find the cause of dampness problem" and without seeing the property.
A good info from masterbuilder link and it does say "it is essential to diagnose the cause of dampness before treatment begins."
Now if you look at the picture,
If the dpc or dpm broken down then I can understand the reason for rising damp. So if the dpc & dpm is in good working order which again is very difficult to know, where else can you get damp problem ? Is it trapped condensation, no air-flow, breathing !, washing machine, double glazed keeping the moisture in and so on.
I'm please to hear masterbuilder methods works & good luck to him. If you look at the picture again and put a chemical treatment on the internal wall, surely the damp will by-pass it higher putting the damp problem somewhere else ? Is it still damp behind the chemical treatment barrier, so it's there all the time and not feel it ? I'm not looking for any argument, I'm trying to get a better understanding.
A Doctor can only guess your illness from the outside unless you have a operation to investigate the root of the problem.
