So we’ve pulled the boards and the end of joist in the corner is soaking wet.!Nothing else is wet and there is no clear indication of leaking pipes. That joist looks fairly new and it looks like they’ve put in a damp membrane course as you can see it.. so I’m suspecting this is either a historic issue and not repaired correctly or reoccurred.
The outside downpipe is still the main suspect at this stage so we’ve cut it (blocked up the hole) and put a new joint in so the water will run down the drive onto the road to see if the joist end dries out over the next week or so. If this is the case the pipe is the problem, if not, something else?
As above, nothing else seems wet in including the brickwork so it can’t be condensation?
All covered up now and carpet back down. I’ll be checking in a week so I’ll take some pictures then. Completely forgot to take any! It’s definitely not a leaking pipe as the only thing there is the gas pipe. The pointing could be making it worse but we haven’t had rain for 2 days and it’s soaking so it must have been really wet if it’s the downpipe!
Very strange the brick isn’t wet and nothing else.
It seems the bay window is from pointing and not sealed properly. Bricky booked for 2 weeks to sort all of the pointing across bay and corner.
Joiner was 95% it’s the downpipe.
If the joist is still that wet in a week then we know we clearly have another issue.
