Hi.
I need to deal with a "rising" damp solid party wall of a 1890s small mid terrace.
(I put rising in quotes as I subscribe to the waste of time of most chemical etc treatments)
The adjoining property has a floor level of 10" or so higher than the one I am dealing with.
I am considering removing plaster to about 20" or so and replacing with insulated plaster board using dabs, then over floating/skimming.
My thoughts and theory are that dabs will hold the insulated board (when it won't hold foil backed board) and a small airflow will be allowed between the board and the wall.
I would welcome your thoughts on my solution to the slight damp problem.
