If the fascia was not replaced and any other rot in the eaves vicinity was not treated then its possible that you might still have continuing fungal problems.
No, your 50mm headlap will have to remain, it should just about do unless water is obviously entering through the short lap.
How water enters & distributes itself in a roof can be tricky to spot and locate - it could be very mild seepage is getting in making identification even harder.
Ref. the support tray and the above details: only by your roofer (or yourself?) going up to the eaves and lifting tile courses, and exposing the fascia & then taking photos can you, the householder, have any idea of whats going on up there.
The support trays should have been installed all along the eaves not just in the photo area.
Best practice and common sense say the tray goes below the felt.
You want to get into the loft and have a clear view of the shallow triangle where the rafters and joists meet the wall plate - pull all insulation away & use a corded inspection lamp.
Your gutter looks to have only been cleaned in that one section.
