That's odd, because in my outhouse, which isn't tanked, I've eliminated the need for tanking by not having a whole bunch of water underneath the floor.
You seem confused. My outhouse has no DPM, or tanking, and it doesn't have a damp problem.
It's better to have DPM below the concrete slab but providing the moisture content is within the manufacturers allowable limits then no problem applying over the top.
So what is it DPM or *no* DPM for the OP? On the one hand you recommend digging up and putting in a DPM, to do a 'proper' job. Then you tell us you don't have a DPM in your dry outhouse.
I was giving you the benefit of the doubt, but I've come to the conclusion that you're a numbskull, so please don't be surprised if you don't get any more replies from me.
What relevance is your dry outhouse to the OP?
Your solution involves digging up and laying a DPM, yet you tell that isn't the reason why your outhouse is dry.
We know what the problem is Only the man on the ground can really establish the source of the problem.
