Thanks Tipper good advice the pipe runs along the side of the house, and we are just south of the Ouse as it enters goole, so the wind can be horrific, i guess also chilled by blowing across a massive expanse of river and no trees, houses etc to break the force, a little insulation can do no harm
Thanks Danoil,
Interesting to hear about the returns, I chatted to the WB engineer tonight who fitted the pump that lasted less than two weeks, he was at a complete loss,last service of the boiler was in April, pretty much every part was replaced due to the boiler being out of action for at least three years apparently so every moving part was stuck fast, he was surprised to hear the oil pump was changed less than two weeks after he had swapped the pump which was fitted in April. When i mentioned i had replaced the pump he said it would be over pressurised and would likely cause sooting so i should take the top off the boiler and hoover it out. Out of interest i guess if i have installed an oil pump myselfy it wont be covered by Danfoss warranty as clearly i am not certified to fit it?
Thanks John
Yes I agree, my limited knowledge of oil boilers aside, the Worcester Bosch engineer who serviced the boiler and replaced the last pump cant say enough about the boiler, 15 years old and it still works like a charm, barring the odd oil pump failure, if i get to the bottom of that then i am sorted. Yes the diverter went about four months ago, i rescued it with an actuator motor from screwfix, going to clean the baffles tomorrow.
Thank you all again
Thanks Danoil,
Thanks John
Thank you all again
