So as you may have gathered I have a problem with the above programmer.
The set up is a Danfoss fp75 and one Myson motorized valve and one pump.
So when switch on the heating side of the programmer, the valve opens and you get rads + hot water.
If you switch on the hot water, the valve closes shutting of the radiators and supplying hot water only.
Simple enough, however in the last couple of days when switching on the central heating it goes on but switches off immediately (using the +1hr function), if you use the timer it just clicks on and off constantly.
The hot water side of the programmer works fine (so i'm using this + the manual over ride to keep the valve open to heat the rads + hot water).
Either the motorized valve or programmer must be at fault - I'm guessing the programmer (it's an old one, everything else was fitted in the last year).
Any suggestions would be welcomed.......
