Can anyone please tell me how I get the plastic cover off this Danfoss unit. Tried the grey knurled part. Won’t budge. Can’t see a locking pin anywhere. Rad is cold. Suspect sticking pin but can’t get to it!
Valve sounds like it is working ok, shut down all the other rads and see if the problem rad heats upYea, I just figured that out . Should it come out any further than 5 or 6mm? I can push it back about 1mm and it springs back again. Obviously under pressure. Maybe the valve isn’t problem then. I’ve bled the rad fine. Water came out immediately. I’ve also made sure the other end is open. The pipe to the thermo valve is warm, the other side cold. All other rads appear to be working fine. Ideas?
