Dead boiler Vailant Ecotec Pro 28
6 Nov 2008
Boiler dead this morning.
240v going in ok. Checked pcb fuse and ok.
not getting continuity across the pcb fuse holder though.
is this a duff pcb or something else?
UPDATE. Managed to get boiler back on but it cut out again after a couple of minutes. This time the pcb fuse has blown. Replaced fuse and this time it cut out. Fuse is fine though.
i unplugged the pump plug from the pcb and powered back up. Boiler power is staying on now. Is this poss a duff pump?
I have checked pump impeller moves freely which it does
got boiler to stabilise but when hot tap is turned on, boiler shuts down
With the boiler off remove the large slot head screw from the front of the pump, insert a screwdriver into the pump and see if it turns freely, it may be seized. You will get some water dribbling out so have a towel ready.
Thanks. Checked that. It moves fine
You can wire the pump directly into a mains supply if you're confident with wiring to see if it works. Use a 5A fuse. You'll soon see if it blows the fuse. So not connected to the boiler electrically at all, just into a mains plug.
Ok. I Can try that. So just remove the wiring in this box on top of the pump and connect some flex with a plug on. I have a 3amp fuse I can use
Ok. Bypassed the wiring and connected to mains supply. Pump is running fine. Usual hum you would expect
boiler is stable but shuts down when hot water or heating is demanded
No pilot light on either.
As soon as hot water is demanded boiler shuts down
If I demand heating. Something runs for about 15 secs then boiler shuts down
Any error code
no error codes.
If I press the live monitor buttons I get S.30 but I assume that’s because it’s stable and not asking for heat. If I turn on heating that code changes to S.02 then boiler shuts down after 10 seconds
normal codes
Have you reinstalled the pump. It won't run without it and will shutdown as soon as it detects a no flow situation.
In that case it should show an error code if it fails to run.
