So if you observe the led panel using the i button what sequence do you get please. Do you have the install instructions? It lists all the S codes to explain their meaning.
Then it's external, S30 is no request for heat.
You should have 240v not 24 on those terminals. Don't like the flash on the pcb thoughBridge removed. Tested voltage at Neutral and the RT terminal 4.
24v present.
nothing at the 24v terminal 3 & neutral
Even with hive disconnected at the boiler and boiler reset it still has a S.30 code when using the buttons to view
Which connection are your external controls connected to?
So if you disconnect these wires from the hive and jumper the two pins on the 24v rt connections the boiler doesnt fire up?
