D
Deleted member 307320
Just had to run in a long temporary run for some Christmas decorations. According to my calcs, the voltage drop with the required load is going to exceed the permissible 5%, and it's not possible to change the cable.
However, the decorations themselves run from a switched mode PSU which will be happy with anything between 110v and 230v so functionally they'll be fine.
In this instance, can I deviate from the regs, assuming disconnection times can still be met?
Cheers!
Cheers!
