If you are driving intensely for long periods then a drill/driver with a large battery is the way for you. probably a 12v as the batteries are smaller and the drill is too, so light on the hand. There are small driver only tools with small batteries and 3 hour chargers, which you will find limiting.
not really - the durofix is a 10.8 volt with a 15 minute charge time - you will not run one battery out while the other is charging , anyway after a hours hard screwing you'll be ready for a cuppa
They are Taiwanese, using Lithium Ion Battery cells from Sony in Japan, not the cheapo cells from China
Only making their own brand in 2006 but made for loads of othe big names for years, Bosch, Snap on etc.
