Hi all,
I'm looking to lay a deck in the corner of my garden to (primarily) support a (right angled) corner arbour, about 2.5m high by 1.5m wide (both directions).
The problem I'm faced with (apart from never having attempted a deck before - but a reasonably competent DIYer) is that the corner of the garden is only 70° and not 90°. Now, I'm planning on pulling the arbour away from the corner to fit (leaving a small space behind, perfect for a pot plant!), but I want to deck right into the corner.
The two long sides are only fenced, so the deck will have to be freestanding and the ground underneath is sloped (less than 300mm along the 3m length) so I'm planning to support the deck on concreted-in posts, aiming for a maximum height of the ground of 200mm.
I've attached a plan of the proposed deck; can anybody even begin to tell me where to site the posts, run the joists and deck the thing for best effect? Comments on recommended joist sizes wouldn't go amiss either!
Many many thank you's!
View media item 20185
