Hi there im new to this site and it seems really good, hope somebody can help me here?
I have an end of terrace house that i have totally revamped and renewed and now i want to do something with the outside. i have quite a large confined concrete back yard. My idea was to split this area into two halves by paving over the bottom half with some nice slate or maybe cobbles...and then if it is possible to put decking down on top of the top half. My questions are 1. Is it possible to lay decking straight on top of the concrete underneath? 2. How should the frame be secured if at all..do i use spots of concrete to hold the corners down or anchor to the walls or what? Does it even need to be anchored anyhow as it will be up against the walls at 2 sides? 3. On the 3rd side is an ACO drain which the deck would run up against , if one side of the frame ran parallell to this the drain..wouldnt this mean that any water under the deck would not be able to flow away and would therefore be trapped against the wood?
Any help appreciated!!! Thankyou!!
