H
herebriefly
Looks like Rooneys training ball. I know he can hit them hard, but.....?
Is it God playing marbles?
Do rocks on the moon land slower due to the lower gravity?
slower than what?
I suppose that they would compared to an earth type planet with no atmosphere ( so no decelleration due to friction with the air )
then assuming the same approach speed, the accelleration due to gravity wouldn't be as strong so it wouldn't be sped up as much.
I'm wondering why it bounced rather than vaporised as it would on earth.
It's the kinetic energy released on the impact that vaporises it - not because it gets warm on the way down. That's why the moon isn't strewn with large boulders.
So this has fallen off the rim of a crater which surrounds the small crater ithas landed in.
What caused it to fall?
Do they have siesmic trembles on the moon?
Did an underground river cause a subsidence?
Was a Moonman collecting for his 'rock' garden?
So many unanswered questions!
And I've just posted my 5,555 post!
Truly amazing!
Kinetic energy is the work required to accelerate an object to a given speed.
no it's not, kinetic energy is the energy an object that is moving has..
if it's already hurtling through space at 5000 miles a second then even with no accelleration from the moon's gravity, it will still impact at 5000 miles a second..
nope. read and learn.
http://hyperphysics.phy-astr.gsu.edu/hbase/ke.html[/QUOTE]
You are both very close with your description, kinetic energy has nothing to do with the initial moving of an object.
If something is stationary, eg a brick on the floor it has potential energy which is the opposite of kinetic energy. Now if i was to pick that brick up and throw it, the potential energy would turn into kinetic energy. Anything that moves will have kinetic energy, whether it is vibration kinetic, rotation kinetic, or translational kinetic.
Basically, kinetic energy is the energy of motion, of something moving
its also the work required to accelerate or decelerate an object. If you have kinetic energy, any change in your velocity requires you to do work or exert work. It hurts when you step in front of a moving bus because the kinetic energy of the bus does work on you as it slows down and you accelerate from zero. So technically, its a measure of the work required to change velocity. The kinetic energy arise as a consequence of the net work done on the object. In this case its called Translational Kinetic Energy, as opposed to Rotational Kinetic Energy.
KE = 1/2 MV^2
go read the damn link.
