Descaling a shower head?
12 Dec 2016
I bought some descaling liquid from plumbing shop. Is it pretty acidic, dangerous stuff?
I live in a hard water area and the showerhead seems to fire water out the side and some holes are blocked. I assume it's the hardwater.
So do i just leave shower head in a bucket of liquid for a few hrs then with gloves rinse thoroughly?
I would have thought that is how you would use it but you need to follow the manufacturers instructions.
As Andy mentioned,change it they are not expensive.
Buy a new shower head with "rub clean faceplate" they have rubberish nozzles and brief rub breaks down scale.
If yours is a handheld showerhead these are good,example here...http://www.mx-group.com/products/shower-accessories/showerheads/synergy-6-mode-white--unpacked-hec/
Try to buy named products not imports from whankingLoveyoulongtime industries (china)
You will find the named products [not sure what that means ] are produced in china.
Soak the head in cider vinegar. Very cheap and quite safe, other vinegars work but cider vinegar seems to work fastest.
Buy 5 L white vinegar around £4.89 (google), in this instance for cleaning purposes only, boil a litre or so in the electric kettle - leave for 20 mins - kettle should be sparkly clean. Reboil, pour hot liquid into measuring jug (or similar) drop the shower head into the hot vinegar, leave for maybe an hour, rinse through - like new !
Filter the cooled vinegar back into container - reuse at will.
