Just swapped old non pumped rayburn royal that managed to heat DHW and 2 small rads as heat sinks.
Now have much beefier 355 model so trying to design a system that will work with minimal interference to existing (upstairs) gravity fed tank and rads. Consulted all the usual channels
My question is that I want to put a rad (last in line) in my office which is below level of rayburn. Where does the pump need to go and will it work?
I'd like to get it right first time, hence the question. I could have the rad mounted half way up the wall to keep same level but it would look silly and loose shelf space...
