- Joined
- 8 May 2017
- Messages
- 9,841
- Reaction score
- 2,507
- Country
If the problem rad heated fully ,all over ,then there is nothing wrong with that rad. Your problem is the system is not balanced.
I've followed all balancing instructions from internet and the plumber went around with a thermometer checking entry and exit points.If the problem rad heated fully ,all over ,then there is nothing wrong with that rad. Your problem is the system is not balanced.
Also ask him how the magic diffuser changes its mind when other rads are turned off.Plumber has been and said the diffuser in the radiator creates this problem and there's nothing we can do.
He reckons that either the internal diffuser is same as many others and makes things worse.
He said more flow/pressure gets water to pass through small holes of the diffuser when all other rads are closed.You should ask him why it heats fully when other rads are turned off.
He did.Why hasn't the plumber balanced the system ,he should have done it when installing the rads??
Why are you doing it ?
Will do.Starting with your system cold ,no radiators on ,start up central heating and go around all rads making a note of those that heat up first / quicker than others. Then each rad that gets hot quickly ,turn down their lockshields half a turn. And see what the problem rad heats like.
