Last night I installed the valves on to my trendy new Bisque designer radiator. I wrapped PTFE tape around the threads and tightened. After filling, there was some water seepage from the joint (not the threads - the other side of the nut).
After numerous further tightenings, it still leaked, so I dismantled, added further PTFE around the joint and some Boss White. It seems OK now but the question is: should I have used PTFE and Boss White, or is an alternative jointing compound (perhaps silicone based) a better idea?
I discovered the radiator has a leaking weld anyway, so I have the opportunity to do it right when the replacement arrives!
