Detecting Compressor slow leak...
23 May 2004
I've got a compressor that has a slow air leak - it takes about 8 hours to lose a full 8 bar charge.
Pressure Switch and relief valve have been changed in the past to cure an over 8 bar charge issue, and I've tightened all connections.
Any ideas as how to detect where the problem is coming from?
Brush liberal amounts of slightly diluted washing up liquid onto every joint and fitting on the compressor and connected airlines. This will bubble up at even the smallest of leaks.
I tried that (remembered from the old bicycle inner tube days), but couldn't see any bubbles...
If your air hoses are rubber, they do tend to become porous after a while.
Have you checked the water drain at the bottom of the receiver?
John :)
Drain is fully closed...
No external rubber hoses...
What do you have on the outlet of the compressor?
If it is a quick disconnect, it maybe that that is leaking, remove it and replace with a blanking plug and re-test.
It may help to strip all joints, clean and re-make using loctite (or similar), as this seals better than PTFE.
Outlet leads straight to flexi hose...
The seal is made with ptfe though.
Most compressors have an nrv on the discharge line and they can leak.
