Just got my DW708, boy what a toy!!! Although its big, it is great, very accurate and easy to use, and the rang of cuts it can do is very impressive. Cant comment on the Makita, but i think it was well worth the money
I havent used the makita but I did read a review about it (after I bought the DW). From what I recall (if I have the right number) it has a slightly larger capacity than the DW and is also slightly cheaper. I have seen them in the local tool store and it does not seem as chunky as the DW but I am sure it is a very fine piece of kit
Ive got a DW708 too Im very happy with it, some slight problems with angles being correct but nothing too severe, 15mins of setup fixed that.
I also got the DeWalt stand with it, and to be honest I could not do without it, cutting 6m lengths of 2x4 isnt easy unless you have the support either side.
I have the DeWalt 708 saw and the DeWalt stand to go with it, these are an excellent combination, I use them for cutting roofs and the accuracy you get makes the job enjoyable (ish!).
Going back to the routers(!) I find having a 1/4 inch one is well worth it. You can use it one handed, and generally far more places than the 2300Watt monsters, such as for hinge recesses on fixed door frames. I often use it in one hand upside down with say a rounding-over bit, and move a piece of wood across it with the other hand. I've had a Bosch one for many years which has a Swiss motor, designed as a toolpost grinder. It's quite a small diameter so it's easy to hold by the body. Also great for sharpening gouges, with a stone capable of running at 30krpm.
