more questions!
I've had a chance to have a good look around my new house and having decided to keep the oil boiler (installed in 2014) I'm now looking at changing the hot water (and maybe heating design).
It's currently got an old uninsulated indirect cylinder (probably there since the house was built in the 1970's) - with a blanket fitted around it and what looks like S-plan heating.
My main question is around running costs.
Assuming all 3 systems are correctly spec'd for size etc - how do the running costs compare of a new indirect cylinder with S-plan, a mains pressure unvented (with S-plan) or a thermal store with a separate heating pump (prob a modulating one - grundfoss alpha or similar)?
Are they all broadly similar in running cost?
I'm also planning to move the boiler into the garage (which is basically behind the wall where it is now), and put the new DHW cylinder next to it in the garage (removing it from the cupboard in a bedroom).
As far as installation costs go I reckon the replacement indirect is by far the cheapest and can be self installed. Ditto the thermal store, but much more expensive to buy.
Mains pressure cylinder, middling to buy - expensive to get installed and annually serviced.
Temperature
At the moment the hot water is scaldingly hot - I could turn down the tank temp - but I believe it has to be at least 60 for legionella?
If I go with the thermal store, then they generally come with TMV's on the plate heat exchanger ( at least the one in my last house did anyway).
If I go with a replacement indirect or mains pressure then can I put a TMV on the tank outlet -or is it generally better (if more expensive) to have TMV's at each bath / shower / tap etc.
Temperature
