Same old problem of long draw off, I decided to put a recirculation loop in. A bit new to this and probably should have researched a bit better. I've looked for similar problems on this forum but can't see anything similar. Apologies if I've missed it.
As I am refurbishing it was easy to put a return pipe from the furthest sink back to the loft. I did this by connecting it up to the cold inlet pipe via a NRV. First question: Is that OK or does it have to be a secondary connection into the tank? I also put an NRV into the cold feed so no danger of it feeding back to anywhere else.
Also, rather than having the pump running all the time wasting hot water, I was thinking about putting 'on-demand' buttons outside bathrooms/ kitchen etc that would only turn the pump on for a few minutes when hot water was required. The buttons would be like the light switches one presses that will turn on for a few minutes and then turn off. Is this a dumb idea? We have unusual usage timings and i didn't want the pump running constantly
The other question is what pump I need, that's not going to cost the earth? I'm UK based. I know Grundfos do 'comfort' pumps but these are £200-300 and was hoping for something a bit cheaper.
The tank is in the loft and I was planning on putting the pump by the last sink on the ground floor which is about 16m of pipe run (each way), so a long pipe run. I bought a pump from Amazon but its not drawing the water off and I think it's not powerful enough: https://www.amazon.co.uk/Circulator.../B079Z832FD/ref=psdc_1938160031_t1_B07QGLKJVD
Any advice on the best way of doing this now I've half done it would be much appreciated.
Cheers
Cheers
