Core drill follows the angle you start with regardless of any pilot hole.Thats why it comes with a centring bit .
Every core bit I used up to 110mm is mounted on stem with 7mm masonry bit which keeps the main bit centred .Core drill follows the angle you start with regardless of any pilot hole.
Ideally hammer off but have used both ways without I’ll effect .Ok. That makes sense now.
So does that mean that you have to use them with the hammer action on?
You are lucky that you didn't have a snatch - no SDS drill I've ever come across is rated more than about 80mm on the clutch, and many are either less or have no clutch at all. That's more of a safety issue to my mind.Before I got the proper drill I managed a few 127mm cores with my 18v DeWalt - but very slow going and ate the batteries (but shows how good modern cordless are). I'd also used an sds (on drill, not hammer setting) but I think the speeds are wrong for diamond cores.
I have to say that for those we simply get the hole drilling man in - and he uses a water-cooled set-up for engineering grade concrete and engineering brick......Accrington brick! rather you than me mate![]()
OP say it does!Does the drill havea safety clutch if not it could break your arm if it locks up.
