Diamond core drill?
17 Feb 2008
Sussex
Im going to drill through a outside wall with a new 110mm dimond core drill bit for a new toilet ive got a 24v drill and a new diamond core drill bit(110mm) and tips off any one?
dont use hammer
wear goggles, ear plugs, dust mask
have hoover collecting dust
make sure you've got spare battery(s)
I'd be surprised if the average 24v drill will be up to the job.
Whatever you use make sure it has a clutch - the core bit is likely to bind at some point and, if the drill has enough torque, will try to spin the drill body round - result injured wrists or, if you lean over the drill a drill in the face!
when you've finished go and buy a new drill as your one will be well and truly fuc**d
You won't even get through the first coarse of bricks. You have a lot to learn. But here is one lesson for starters, battery drills are toys. You need mains power for a task like that, I always opt for 110v.
